Alignment 01
, 14-04-2012 at 09:48 PM (3843 Views)
Looks like someone with not much experience on NSX alignment carried out the process
in the past.
These two arrows at the rear toe control arm should be lined up otherwise, the ball
joint won’t have enough travel under certain conditions.
Loosen the lock nuts and apply silicone grease to prevent the moisture causing oxidized
corrosion inside the rod.
What a super tight self locking nut at the rear camber adjuster……
Normally, I can loosen it by just using my arm but for the first time, I had to apply
significant amount of force on both sides to just rotate it slightly.
The bolt was not seized to the metal collar of the bush so it’s just the self locking
nut seized on the thread.
I was worried about damaging or even stripping the bolt but finally, both adjusters
came off and managed to apply the silicone grease.
