Alignment 01
, 28-02-2012 at 10:01 PM (4890 Views)
Before visiting the alignment platform, it is my standard practice to check
the state of the alignment adjusters and apply silicone grease to the adjuster body.
Rear side was done while working on the drive shaft and other services so
working on the front side at the moment.
The camber adjuster was slightly oxidised but not too bad.
The tie rod was really rusty and took a while to free up the lock nut.
Also, it was not fun trying to rotate the rod arm using 12mm spanner
as it was heavily corroded.
As seen on many NSX, the Caster adjuster at both R & L side were seized.
Looking at the blue marker paint, it looked like both sides were never adjusted
since leaving the factory so it would be interesting to see the alignment data.
So many NSX with EPS showed tiny rattle at the passenger side rack end.
Most of the cases were due to the wear at the collar/bush inside the EPS rack but
from time to time, the actual rack end or tie rod itself could cause this.
So, before the alignment service, it is important to confirm the cause of the issue
because if you replace the tie rod or rack end, you must carry out the alignment
service again.
So, opened up the rubber boot and confirmed that there was no play at all
at the locking washer/nut/thread at the rack end.
The tie rod ball joint was fine and thus, it confirmed that the rattle was caused by
the issue inside the EPS rack.
By the way, the locking band for the rubber boot was positioned in a way that
it was not possible to remove it without cutting it.
Normally, I can remove and re-use it without any issues so possibly removed in the past???
In Japan, KEP Engineering has been offering the EPS rack overhaul service for
many years at very reasonable cost.
They spent lots of time and money to acquire the know-how and developed
the special jig.
(All three above photos are courtesy of KSP Engineering, Japan.)
Without actually operating the EPS rack with the EPS controller under specific load
using the jig during the re-assembly process, you won’t be able to adjust several
critical parts and it is very likely to cause noise/issue in the future even after it
was overhauled.
Because of their achievement, now-a-days, even the Honda garage in Japan are
sending the EPS rack to them for overahul based on the request from the owners.
I hope I can do something for UK based NSX as well.
So, ready to go for the alignment service.
