Wheel Speed Sensor and Drive Shaft 06
, 20-01-2011 at 10:49 PM (4258 Views)
Shiny wheel speed trigger teeth.
Looks much better from the sensor point of view.
I used to have access to all sorts of tools including the high lift transmission jack that is a great help for the installation of Left drive shaft.
As I no longer have access to this specific jack, I always need to hold the outer joint on my shoulder and set the drive shaft at a certain angle so that the inner joint can be inserted to the trans case without damaging the seal.
Drive shaft installed.
