Eng Refresh Stage 1 - 03
, 06-12-2011 at 10:01 PM (2467 Views)
Had bit of a trouble embedding the image file from other site so only managed to update the Blog now.
Everything was going smoothly until today.
Initially, I was bit worried about the state of the previous services when I found out that some of the valve cover gaskets/seals were not installed properly and being damaged. Also, some of the bolts at the TB covers were not torqued at all and just left with finger tight only.
These are nothing new to me as I experienced similar cases on many UK based NSX and you can see some of them within the archive of my Blog.
Today, I had big issue with one of the bolts holding the A/C Idler pulley bracket.
It was cross threaded and considering the limited space available, I really wanted to avoid searing off the bolt head.
I couldn’t go any further with the TB service without removing this bolt so after some consideration on the material used, decided to use ‘the two turn forward, one backward’ method even it would take hours to drive the bolt out.
After long hours, finally the bolt came out.
I can easily re-thread the bolt body but I’m 100% sure that it will take another long hours to re-thread the mating bolt hole on the engine side.
I’ll deal with it once I have started tilting the engine for the TB service.
Challenge continues...
