CL Hyd System 02
, 16-11-2011 at 10:01 PM (2008 Views)
Seems like the site is back online again so I’ll back date the posts.
So, started to remove the existing CL Hyd parts and as suspected, the Slave Cyl was leaking.
New Master Cyl.
After pouring small amount of brake fluid just to prime it, installed it.
You should replace CL Master, Slave and Hose as a set so new Slave Cyl, Hose and bolts ready to be replaced.
