CL Hyd System 01
, 15-11-2011 at 10:24 PM (2690 Views)
The owner commented that from time to time, he was having difficulty on selecting gears on downshift only.
He didn’t feel any issues for selecting 1st or Reverse gear from standstill and no issues with upshift.
I suggested the owner that it is very unlikely to be Clutch (CL) Hydraulic (Hyd) System related but the owner wanted to replace it any way as there was a sign of leakage at the Slave Cyl and start from there.
I test drove this NSX several times over the past few years and every time I noticed that the gear shift was somewhat notchy regardless of the GBox temperature or even after replacing the MTF.
May be the word ‘notchy’ is not correct.
It’s more like ‘heavy’ just before selecting the gear and not exactly the same but similar to the feeling when you have installed a brand new shift cable.
You will be amazed how heavy it feels and even regret for a long time until it start feeling smooth after replacing this long pair of cables….
This NSX is at very low mileage and not used regularly so that won’t help….
Any way, before touching anything, wanted to confirm the owner’s comment so took the car on the road.
First thing I noticed was the extra play at the CL pedal resulting in bit too high initial height.
By now, everyone knows that our NSX has quite high CL bite point at the pedal and thus, fairly high initial CL pedal height compared to other sports cars.
It is quite common among the NSX owners in Japan to replace the CL pedal to Type-R spec together with the damperless joint on the CL Hyd system for this particular reason.
Once it's done, the initial height of the CL pedal will be lowerd and it will be almost at the same height as the Brake pedal like this.
On this NSX, while the pushrod on the master cyl was not touched (and normally, you should not), it looked like someone removed the CL pedal switch and didn’t put it back to the original position.
There was a little extra play at the beginning of the pedal stroke.
Will be checking the CL pedal height any way after replacing the master cyl.
During the short test driving session, never experienced the downshift issue but once again, I felt moving the shift lever was notchy/heavy.
Neither sudden pop out of the gear nor vibration through the shift lever while applying on/off throttle in 1st and 2nd gears so snap ring seemed to be fine.
Normally, I don’t open or remove the shift cable while replacing the CL Slave Cyl and CL Hose but may need to do so just to see how the cables and the shift linkage are moving inside that white plastic cover.
More to follow.
