Alignment Service 02
, 30-09-2011 at 11:34 PM (14142 Views)
During the last Health Check, I noticed that there was a tiny up/down movement at the FL rack end.
Also, from time to time, when I turn the steering wheel, I heard clicking sound.
These are quite common issues on the power steering rack but in order to confirm that it was not caused by the loose rack end, opened up the rubber boot and checked the condition of locking washer as well as any movement at the rack end.
There was no movement at all so wiped off the old grease and re-greased it before closing the boot again.
This confirmed that the movement and noise were coming from the power steering rack.
The bush/collar holding the spiral assist rack got worn and unfortunately, Honda doesn’t sell this part alone.
They only supply it as part of whole steering rack that is mega expensive.
In Japan, KSP Engineering developed their own jig and know-how on refurbishing the EPS steering rack and nowadays, even some of the Honda garages are sending the rack to them to solve this small movement and noise at the EPS rack.
I will touch on this in the future.
What a tight locking nut and corroded thread at the FL tierod.
Managed to move the lock nut but the thread of the rack end screwed into the tierod was heavily corroded and seized that it was almost impossible to turn the shaft with 12mm spanner.
I thought about even applying the heat if acetone/ATF fluid didn’t do the magic.
After soaking it over night, finally, it started to rotate slowly.
As seen on many NSX, both Caster adjustor were already seized.
Will see how they go at the alignment place.
So, all of the alignment adjuster bolts and nuts were checked and treated so I’m ready to book the alignment platform.
It will be early next week.
Time for the test driving session.
