ABS Upgrade 09 - Pressure Bleed
, 13-01-2011 at 12:55 AM (3131 Views)
Time to pressure bleed the entire system.
The traditional theory of bleeding from the furthest point from the brake master cyl won’t apply for some of the modern cars.
In fact, you can’t even bleed the air on some of the models without activating their ABS modulator.
For most of the latest ABS on NSX, S2000, etc, you will bleed the system from the front side.
You can still use the old theory but it may take extra time and you will waste more fluid.
So, pretty much done with the ABS Upgrade.....
Will leave the car on the lift over night for leak check, quick test driving session and should be done for the ABS upgrade.
Needs to work on the Left driveshaft and the dirty A/C blower fan…
