ABS Upgrade 07
, 13-01-2011 at 12:35 AM (2346 Views)
For the latest ABS, Proportioning Valve (PV) was added to the system.
It is placed just below the ABS modulator.
Rest of the pipes for the PV installed and connected briefly.
Time to start tightening each fittings to the specified torque before installing the two pipes to the master cyl.
Otherwise, you will struggle to swing your torque wrench.
Double check that none of the pipes are touching each other or any of the body work to prevent future damage.
As you will need to check several areas from different angle/direction, without the lift, it is time consuming and you may not be able to check the crucial points….
