Bose Speaker AMP Service 04
, 12-08-2011 at 11:24 PM (2239 Views)
After applying the thermal compound and conformal coating, the front AMPs were ready to be installed back to the speaker box.
Now they are back on the car and being tested together with the aftermarket woofers and tweeters.
One tip for you.
Whenever you have removed the door card, make sure to fill in some silicone compound into the non-water proof connectors especially the 3pin door lock/unlock switch one.
Sooner or later, the female terminal will corrode and starts to fail.
At the driver side, you have several connectors that require this treatment.
