Interior noise 02
, 25-07-2011 at 11:38 PM (1672 Views)
I need to be careful if I’m going to remove the door card because the door handle is already showing sign of crack….
Poor A pillar trim at the left side…
The bottom corner was not installed properly and forced behind the dashboard resulting in surface material squashed.
Looks like people who are not familiar with NSX worked on this one….
Lots of poor repair work were found on the centre air vent, clock, centre console and so on.
These are from the centre console.
The bracket holding the four switches behind the shift lever was heavily damaged. Looked like it was glued and different colour screws were used for the repair.
The mounting bracket around the cabin temperature sensor were also damaged.
Instead of reparing all of them, probably cheaper to replace the console with new one from Japan.
For the time being, I'm going to reuse it.
