Fuel Lid Alignment
, 22-07-2011 at 11:35 PM (2046 Views)
I noticed that the fuel lid stayed closed even when the opener lever was lifted.
Already there were some signs of someone tried to adjust the alignment in the past.
So, removed the lid and found that the actual hinge was bent in the past causing very heavy movement.
Greased it and moved the position of the spring and at the moment, it works fine but when the temperature drops, not sure about it.
Let’s see how it goes.
