View RSS Feed
Heineken's Garage
Radio Head Unit - Repair IV
Rate this Entry
.. continuation of Radio Head Unit - Repair III
No display - otherwise fully functional
Observed on: 1 USDM Radio
Fixed by: PCB repair
, parts replacement
State: Fully understood
A fully working radio with a non-working display. The display was confirmed OK by installing it into a working JDM radio. An investigation showed heavy leakage by capacitor E818:
IC 802 is providing 9 V to the VFD heater circuit (required for the display to work) and is switched-on by Q827.
Name:	Screenshot from 2025-10-06 19-12-30.png
Since PCB traces were damaged and Q827 destroyed, IC802 could no longer be activated. There's no 9V reaching the VDF heater circuit and the display isn't working.
Trace repair and replacement of Q827 restores full functionality.
Volume control needs "Warm-Up" to work normally
<TBD>
Updated 07-10-2025 at 06:46 PM by Heineken
Tags: None Add / Edit Tags
Categories
Member's Blogs , Technical Information
Comments
  1. Heineken's Avatar
    Added info about non-working display on otherwise correctly functioning radio.
