Drive shaft 08
, 14-07-2011 at 08:47 PM (2613 Views)
Each joint housing has been cleaned to this level for thorough inspection.
Shaft being painted and placed white mark for the RH MT drive shaft.
Make sure to place each roller back to its original position with original orientation in the joint.
So, something looked like this is now overhauled to this level.
Applied silicone spray at the spline, rubber boot and wheel speed trigger teeth to prevent the joint from corrosion and the boot from cracking.
