View RSS Feed
Heineken's Garage
Radio Head Unit - Repair III
Rate this Entry
.. continuation of Radio Head Unit - Repair II
CD port not working (e. g. channel loss)
Observed on: 2 EUDM Radio
Fixed by: PCB repair, replacement of OP amp (with
adapter PCB, if required)
State: Fully understood
Acid damage to the traces around the CD port OP amplifier can cause the connection to the CD changer to fail.
severe trace damage around the CD port OP amp mounting point
The CD port should be removed and cleaned. In addition to repairing the broken traces, all VIAs in the area should to be reinforced by soldering a thin wire through them. The OP amp usually requires replacement, too.
repaired area with new OP amp
The original OP amp, especially in it's metric size packaging, is no longer available but can be replaced with a standard SMD 4580 dual OP amp from JRC or NJM when carefully placing it on the existing connection pads.
In case the solder points of the OP amp are no longer existing it's possible to put the NJM 4580 on an adapter board (SO8 to DIP8) and connect it using jumper wires. The adapter PCB can be mounted on the main PCB by means of heavy duty foam padded double sided tape.
Intermittent complete loss of sound
Observed on: 1 USDM Radio
Fixed by: PCB repair, replacement of flex cable and flex cable connector
Acid damage to the flex cable connectors causes intermittent connections. Such contaminated connections can be identified by a greenish colour visible on the flex cable and/or the connector:
green stains on the cable
a contaminated connector
Measuring the connector's pins against each other (after removal from the PCB) showed resistances of less than 200 kΩ - in an OK connector they should be >2 MΩ. Replacement of the connector and flex cable is required. Acid-affected areas on the PCB need to be cleaned-up, too.
Intermittent complete loss of sound II
Observed on: 1 EUDM Radio
A previously repaired radio, working fine for a maximum of 5-20 minutes, followed by complete loss of sound. The 10 V supply dropped from 10 V to 3.9 when the audio stopped.
some chips with 10 V supply (V+): IC206, IC205, IC307, IC304 and IC305 (not seen above)
Most operational amplifiers on the PCB depend on 10 V and a drop affects the whole audio path. Below circuit shows that enabling the 10 V supply requires battery voltage to be present on the B.T.T. pin as well as +5 V on the PCNT pin of the main flex cables. The voltage is created by the Zener diode ZD807 and needs to show a correct 10.8 V when the radio is switched on.
Name:	Screenshot from 2025-06-20 13-03-37.jpg
10 V power supply switching and routing
A broken trace caused the voltage not to reach the amplifier chips. Below (yellow) repair trace connects the output of ZD807 to V+ of IC205 and restores full functionality.
the yellow repair cable restores the 10 V supply
Strong distortions from CD Changer
If sound from Radio and cassette are fine but the CD Changer shows harsh distortions on top of barely audible sound, the CD changer OP amp and related circuitry is probably the reason. Capacitor liquid damage usually requires trace and VIA repair as well as replacement of the OP amp (see CD port not working above). Take care of these issues before further trouble shooting.
Name:	Screenshot from 2025-03-23 11-07-04.jpg
CD Changer OP amp JRC4560 circuit
Measure the voltage at the positive lead of E817 - it should measure between 5 and 6 Volt. If it's significant less or close to 0 Volt, this trace on the back of the PCB might be interrupted:
proper connection into all three directions required
Capacitor liquid induced damage can disconnect the positive lead from E817 from the vertical trace into the small, brown SMD capacitor. If this connection is lost, the CD audio signal isn't DC shifted which prevents the OP amp from amplifying it properly. Since the OP amp power supply is DC only, it can only process DC but audio from the CD changer is AC and therefore needs to be shifted up by 5-6 Volts to make it DC only.
Volume control needs "Warm-Up" to work normally
<TBD>
Updated 20-06-2025 at 11:06 AM by Heineken
Tags: None Add / Edit Tags
Categories
Uncategorized
Comments
  1. Heineken's Avatar
    Added Information about Intermittent complete loss of sound.
  2. Heineken's Avatar
    Added information and schematics on Intermittent complete loss of sound II.
  3. Heineken's Avatar
    Added information and schematics about Strong distortions from CD Changer (CD changer OP amp circuit and diagram)
  4. Heineken's Avatar
    Added information about the usage of an adapter PCB for the CD changer OP amp.
