Cooling Sys, Health Check, etc 23
, 07-12-2020 at 10:01 PM (1097 Views)
The owner lost the tow hook cover several times in the past so just created tiny metal loop at the back of the new cover and used cable tie to prevent it from flying away.
Saw the same issue and multiple different methods used on Prime long time ago.
As reported earlier, this NSX arrived with partially dead aftermarket antenna.
Very popular mod in Japan using the S2000 antenna with the signal AMP.
NSX is from the old concept of preventing the GND loop instead of digitally dealing with it.
Already the factory loom was cut so can't do much….
Proper mating connector for the AMP power line.
Always looks very nice especially on the dark body colour.
Compared to Japan with more than 50% of the land covered in mountain, UK is fairly flat so quite easy getting the vertical and horizontal waves even with the multi-path/phase noise.
So many stations were received even before applying the power to the AMP.
