Cooling Sys, Health Check, etc 06
, 22-10-2020 at 11:47 AM (1193 Views)
Very suspicious looking coolant hose under the tank.
Later after removal, confirmed that the fibre layer was already breached.
The hose was expanded and about to explode.
Very lucky owner.
It's getting common these days.
Another NSX with leaky radiator.
And as always, lower bolts holding the rad fan shroud were completely corroded and rounded......
Replaced with Koyo Racing Rad.
As my standard procedure, on purposely installed the new hose and hose cramp in this angle/position considering the design of the aftermarket hose neck.
Gave good cleaning around the rad fan shroud before installing it to the radiator.
As in the upper photo, one of the holder bracket was partially dead so used large washer to support it.
