Cooling Sys, Health Check, etc 02
, 26-09-2020 at 02:20 PM (1903 Views)
The A/C compressor CL didn't engage.
It was 26degC outside even in the late afternoon and very humid….
No chance of engaging the CL at such low level refrigerant.
It's leaking from the evaporator fitting at the front bulkhead.
Also, leaking from the compressor piston chamber seal as well.
Will be carrying out the A/C Refresh in the future.
This NSX has aftermarket antenna and it's already broken and doesn't retract.
Same thing happens on any mast antenna, just like on my boss's MX-5.
It's caused by the worn and broken plastic geared reel/cable.
Not much point repairing this aftermarket one as someone already tried and failed.
Even some damages to the housing body.
After some discussion, going to install the S2000 OEM version.
