Eng Refresh, Health Check, etc 16
, 27-01-2020 at 02:05 PM (2309 Views)
Started the initial cleaning process for better inspection but not removed the old liquid gasket yet.
I must first prepare the area to prevent any residue dropping inside the Eng.
Such a lot of liquid gasket everywhere.......
Will create before/after photo later but for now, just this one.
As seen on other NSX, bit heavy marking on #3 inlet rocker arms due to lack of use and oil passage design with VTEC on NSX but not too bad at all.
In the process of carefully inspecting the cam shaft, cam cap, etc.
Will move onto the 2nd stage cleaning process and hope I can start the re-assembly process very soon.
