StopTech BBK, etc 15
, 27-03-2019 at 12:29 PM (2058 Views)
Fair amount of dust trapped but enough light can pass through so going to re-use the air cleaner element.
CL Hys sys is a single piston design with no center valve so nothing special for bleeding.
Adjusted the fluid level to the max line.
While carrying out the vacuum leak check of the cooling system, doing other tasks in parallel….
Not sure of the benefit of these aftermarket magnetized drain bolt but just cleaned and re-installed.
Looks like this valve cover coating is not strong enough….
New OEM fuel filter installed.
My standard procedure for changing the eng oil and filter…..
