ABS Upgrade (non-NSX), Health Check 02
, 23-12-2018 at 03:00 PM (1804 Views)
Then, the reset sequence.
This time, no problem in erasing the code and at the end, the two short flashes of ABS light confirming that the reset was successful.
After the reset and without removing the SCS terminal from the GND, the system will be in error code reading mode and when there is no code stored, the ABS light will stay On permanently after the first bulb check mode.
Didn't have time setting up the bench system again to test why I couldn't reset it on the bench but another owner had exactly the same phenomenon after the ABS upgrade with his NSX but using the NSX modulator and the real chassis loom with all sensors input already connected and not on the bench so there must be a specific condition.
Any way, at least, the logic side of this used AP1 modulator looked to be fine and I'll only know about the state of the hydraulic side once it has been installed on the NSX.
Moving onto the Health Check and actual ABS upgrade hardware isntallation.
