View RSS Feed
Wheel Lock Nut
Rate this Entry
Glad I can still order this wheel lock nut as it's shared with modern Honda models as well.
Probably Honda-McGard one offers better security but depending on the design of the OEM wheel, this one provides better appearance.
This one is chrome finish.
Categories
Parts
Comments
  1. NSXGB's Avatar
    Hey Kaz, do you know if are they available in black?
    Hope you are feeling better soon.
  2. Kaz-kzukNA1's Avatar
    In 1994, I bought 08W42-SL0-000 (black finish) but it was discontinued long time ago.
    Modern Honda models are using different hub bolt size so I don't know whether it will fit or not but 08W42-SNW-000 is in black finish and could be suitable for our NSX but don't count on me for this as I have never used it on my NSX….
    I may order a set for myself as I replaced the rest of the standard black wheel nuts several times in the past and just done another round but without the wheel lock nuts so good test fitting opportunity.
    Updated 01-12-2018 at 07:30 PM by Kaz-kzukNA1 (extra info)
  3. NSXGB's Avatar
    Thank you, I will check it out.
  4. Kaz-kzukNA1's Avatar
    Standard OEM nut
    Wheel lock nut
    Just got the delivery of 08W42-SNW-000 and I can confirm that it's the correct one for our NSX and it's in black finish.
    As always, the wheel lock nut has significant difference in weight compared to the standard one so please consider where to fit it.
  5. exiges1's Avatar
    Hi Kaz, is that the U.K. part number?
  6. Kaz-kzukNA1's Avatar
    Good point.
    I think code SNW is for the FD2 4Dr Civic that was only available for Japan market???
    If so, probably not easy getting it through HUK.
    Looks like Lings Honda website is changing so not easy searching for the parts using the OEM parts no.....
  7. NSXGB's Avatar
    Quote Originally Posted by exiges1
    Are you interested in these for your aftermarket rims Tony? I don't believe they will fit as your wheels will most likely have tapered seats.
  8. exiges1's Avatar
    Thanks for the reminder Simon. No it’s not for those but in case I want to put my OEM 7 spokes back on in the future.
    Merry Xmas!
