Eng Refresh, Cooling Sys, etc 13
, 28-08-2018 at 12:51 PM (1839 Views)
As seen on many NSX, the TB Rear cover showed lots and lots of scratch markings, very likely to be from the previous TB service.
Will measure the existing valve clearance, cam timing, TB tension, etc before start backing off the valve clearance adjuster in preparation for the cam shaft removal.
