ABS Upgrade, Oil Cooler, etc 06
, 03-08-2018 at 03:01 PM (1644 Views)
Not toqued yet but the most time consuming task of installing the ABS Upgrade pipes are done.
Always double or even triple check the clearance of each pipes against each others as well as against the body panels, etc.
Changes in temperature and vibration will expand/contract the pipe so must take these into consideration.
Now time to deal with that extra wires inside the cabin before installing the ABS Upgrade loom.....
I hate these spaghetti job done by someone.....
