Cooling Sys, ABS Upgrade, etc 21
, 26-06-2018 at 06:42 AM (1652 Views)
All I wanted was to access these two orange connectors from the original ABS controller but where all these extra wires came from…..
Ver.023 classic ABS controller for 97+ models.
Just placing the SRS unit in this orientation while taking the photo.
Please always store it with the black surface up.
You don't want launching the entire unit in the air with accidental deployment.
Silicone sealant applied to seal the small slit at the bulkhead grommet where ABS upgrade loom was installed.
Can't fireup the eng and with the battery tray still off the car, just quick power up using the jump battery to check the ABS light logic.
After 2sec, the light goes off.
Also, carried out the Reset procedure using the ABS dedicated SCS terminal, brake pedal and IGSW.
After the sequences, the ABS light flashed twice so the system is operating properly. Good.
I'm using the proper terminal here but you can use paper clip instead on this SCS terminal as it's not used by mating connector.
Just needs to create short circuit to the GND.
