Cooling Sys, ABS Upgrade, etc 05
, 11-06-2018 at 03:00 PM (1707 Views)
Front valve cover not installed properly, seeping oil at the TB front cover.
The DIY install of Denso ACG by the owner.
Looking nice.
Later, I had to remove it as the CYL/CRK sensor loom was not installed properly long time ago.
I better check each tube connection because some of them looked as if installed at different port......
Very suspicious wet marking at the left a/c condenser.
Probably leaking the compressor oil but can't confirm as I don't want keeping high pressure nitrogen tank inside my garage.
As seen on many NSX, another one with leaked marking on the radiator.
The owner is already on the case with the tyre…
Suspicious dry coolant markings.....
Hope it's from one of the narrow coolant hose that was nearly/already punctured (pin hole) by the sharp edge of the TH body.....
Another NSX with rear bank header hitting the sub frame.
I don't know how people is going to tilt the engine during the TB service with this header unless taking the eng/gbox out of the bay.
