Cooling Sys, Fuel Pump Resistor, etc 19
, 24-04-2018 at 09:37 PM (1877 Views)
Addition to the parts from Mike at R-Motion, all parts from Japan arrived.
VVIS chamber re-built and intake manifold back on the engine.
No point in leaving dirty IAT sensor so cleaned it to this level and replaced the o-ring.
While waiting for the parts from Japan, vacuum leak check was carried out so just a quick check again followed by vacuum fill.
Didn't like how the front O2 sensor cable was routed and also scratching against the front cross beam so re-routed it to OEM spec.
