Cooling Sys, Fuel Pump Resistor, etc 04
, 07-04-2018 at 02:26 PM (1624 Views)
No option but to replace the rear brake pad....
Normally, you would consider the brake balance between the F & R but after looking at the make/model of the existing pad used at the rear, anything would be an upgrade.
EBC Redstuff to be installed. Only 2set left at the time of placing order. Hope they will make more....
