Cooling Sys, Fuel Pump Resistor, etc 02
, 07-04-2018 at 02:05 PM (1622 Views)
As a pre-caution, measured the fuel pressure and replaced the fuel pump relay.
The naming is bit confusing as it's actually a resistor bypass relay.
This is DBW model.
Completely seized and oxidised heater core bleeder plug.
I thought I'm going to kink this aluminium pipe.
Very loose bleeder plug at the firewall but not enough to cause leakage.
Carried out Eng block test and reported the result to the owner.
