Brake OH, DR shaft, etc 19
, 13-03-2018 at 11:52 AM (1802 Views)
Came out fairly nice and it will probably survive the street driving conditions for a while but no chance against the heat of track day hard braking.
Back on the car.
I prefer not using the shim to keep rock solid pedal feeling although it may cause squeaking noise when the pad initially bites the disc.
However, it's just me so installed the shim as specified in the manual.
On later model, Honda took off some of the shims from the factory.
The usual EBC Redstuff rear brake pad contents.
