Eng Refresh + LMA, Health Check, etc 70
, 26-10-2017 at 02:02 PM (1728 Views)
Right outboard joint rollers.
As suspected, they were absolutely at the limit-limit for re-use.
The grease used on these CV joints are designed to work under high stress/temperature so if I felt any extra play, I would have rejected them and replaced the entire joint as a set.
So much damages were done but the grease will do its job.
