Drive shaft 01
, 06-06-2011 at 11:22 PM (4002 Views)
Once again, time to work on the drive shaft.
Although both spindle nut were very tight, managed to remove them by soaking them in the penetrating oil over night.
However, at least the right side one looked to be never removed from the hub in the past.
It is super tight and won’t move at all even using the hydraulic puller.
I think I need to create a small dam and flood the spline area with the special oil and try it again later…
