Eng Refresh + LMA, Health Check, etc 59
, 08-10-2017 at 12:04 PM (3205 Views)
Eng loom ECU connectors, etc back into the cabin.
Pretty much upper side of the engine is done and nearly ready for the eng fireup.
Just need coolant tank installed.
This side is also ready.
All four mounts and the sub frame should be torqued at specific sequence.
If you study the design of the sub frame and how the eng/gbox assy are mounted, you will understand the reason.
This is the rear mount and the last one to be torqued.
Hope to fire up the engine very soon and once the parking brake connected, I can start removing the drive shaft.
Getting there.
