Eng Refresh + LMA, Health Check, etc 47
, 27-09-2017 at 10:55 AM (3363 Views)
ACG, aux belts, etc back in place.
Forgot to take the photo but P08 spec filter and gasket installed after cleaning the Rear VTEC spool valve.
Hope I will remember taking the photo of the new filter/gasket before installing the front side.
The vacuum pipe, tube and loom are now back in place.
Getting ready to place the eng/gbox back in the bay.
I need to check the dish washer today…….
After about 16 years of usage, looks like the circulation pump is getting tired or something trapped that it's not generating high enough pressure.
The swing arm only operates at very slow speed and the pressure is so low that it can't spray from the top section….
If motor has to be replaced, probably best getting new one considering the age…..
