Eng Refresh + LMA, Health Check, etc 06
, 20-08-2017 at 11:55 AM (2326 Views)
With JDM tail light assy, you will have 3 x 5W position light per side.
At the Left side, the most inward single 5W bulb was very dark.
Please replace it.
Missing the fixing screw at the sun visor.
The cabin room lamp had some sort of black coating but it was disturbing the GND and causing intermittent connection failure.
Peeled off the coating enough and now it works.
I'm afraid even the owner had extensive A/C refresh in the past, the refrigerant level was already getting low and at least, I can see it's leaking from the following places;
The Hi side charge port (Shrader valve), compressor front/rear section, front bulkhead at the evaporator fittings, etc.
