Brake OH, Health Check, etc 09
, 04-08-2017 at 10:42 AM (2447 Views)
Must test the smooth movement of the pistons for checking the seating of dust boots and the seals.
This is how the original caliper should look like when leaving the factory.
OEM brake hose fitting is showing no sign of rust so re-used.
Double checking the installation.
Should be able to finish the rear side today and bench bleed the master cyl.
With the change in plan, managed to finish the MOT on MX-5 yesterday and hope to returning this NSX to the owner early next week.
Probably have to work on this NSX over the weekend as there are so many others in the queue......
