Eng Refresh + LMA, etc 56
, 30-05-2017 at 09:35 PM (3334 Views)
Left door speaker AMP refurbished and back in the box.
Foot well bass AMP also ready to go back into the car.
As reported earlier, no point in restoring the heavily damaged weatherproof sheet so just a quick repair to prevent moisture getting in contact with the door card.
Please replace it with a new one next time.
Proper shorter speaker box screws used this time.
The courtesy light was not even connected so re-connected it and L side door is done.
You can see the effect of moisture turning the door trim into white-ish stain markings.
There were so many extra wires, components, etc behind this carpet and below the glove box.
Possibly from the remote engine starter installed while this NSX was in Japan.
I now know why the knee panel under the glove box was not installed properly.
Because of the obstruction, it was not possible to use OEM method so someone just left it sitting at the carpet.
Tried my best modifying the vertical section of the floor carpet so that at least, it won’t reduce the foot area for the passenger.
