Eng Refresh + LMA, etc 55
, 29-05-2017 at 03:05 PM (6002 Views)
By the way, it is important not to operate the compressor if there is not enough refrigerant left in the system.
This NSX lost almost all of the refrigerant that the triple pressure switch under the bonnet didn’t allow the compressor clutch to engage.
So, during the Function & Operation check, didn’t want running the engine when testing the compressor CL feature.
Override the pressure switch and just monitored the gap change at the compressor CL when the condenser fan engages.
In this way, you can confirm that the a/c ccu, ecu and FCU are working together fine without running the engine.
