Eng Refresh + LMA, etc 46
, 24-05-2017 at 10:42 AM (4399 Views)
Difficult time for everyone but life moves on.
Hope the owners, family, friends are all safe.
Pretty much this side of the engine is ready for re-connecting the battery.
Not everything back in place but already making huge difference on the appearance.
Before/after.
Managed to drain further about 300cc of old eng oil from the top.
New OEM short filter filled with fresh oil.
The Honda ATF-DW1.
For now, I filled the gbox with 4.5L after draining about 5.2L.
Will adjust the level once fired up and after the test driving session.
Treated the new header tank with 303 protectant.
One benefit of huge delay in service is that I now have the eng glass hatch damper.
I never had problem sending these from Japan for many years but for the first time, the package was held by Japanese authority.
I have no idea how they managed to detect such small amount of high pressure damper gas packed together with so many other metal parts but any way,
had to find alternative method.
I know one courier company can air freight the suspension damper but not cost effective for just this small parts.
Fortunately, my boss was about to return from Japan so asked her to hand carry them back with no problem.
As seen on NSX Prime, addition to the boot lid damper, Showa is now manufacturing these in China.
No problem as long as the quality control is done properly.
New GND cable and battery back in place.
As mentioned many times, never over-tighten the battery clamp.
If done properly, you should see some gap at the craw.
