Eng Refresh + LMA, etc 34
, 06-05-2017 at 10:52 AM (2749 Views)
When I looked at this coolant hose, it felt bit strange as the opening didnt have sharp edge.
Almost like not being cut after removed from the mandrel.
And it confirmed it.
Too long compared to the other batch.
Not a big issue as the base shape is correct so just used the other hose as a template and cut it at the proper length/shape.
Thermostat cover cleaned to this level.
Thought about replacing it but considering the rad fan sensor, still cheaper to clean it than replacing.
New thermostat installed
This is the hose that was not cut at the right length.
