Eng Refresh + LMA, etc 22
, 26-04-2017 at 01:17 PM (3299 Views)
Replaced the crank oil seal.
Unlike some of other engines, not so often to see actual leakage but while removing the existing one, found out that it was indeed leaking on this one.
Removing the old red sealant in preparation for the WP and Oil cooler installation.
[IMG]https://lh3.googleusercontent.com/viqXC9qbZbv2daitdZCTkm0WYhJi6T9-NA9OrWqwBN5dQnvn0OzvffDea-***_rH3y-HJsQ4IxlDGPVHHnvcHGDBqvuaMcxhbNIQIvA_6JF69kwDDmDjh Bi01BOXLHRw18Jr2ySUOSbaGJEEuqJvD1RnDlDTkpMO4T0M_Q_ cFTPey66fddiLq70E0uY-6dJAKYs7MoIppGRap1-iUVA6jkU3Ngu7FEDHLAlG5siYtXOOakbYtFJSDIcHf0pQPO8U6 QxL91R5nmFyE2rL8IDjx7AgGRqFQ6PfFufS2XQWyBsfzV4jZLh P0osU96uzteSep_qV3eCv9rCeiaYdFsIPPGsO22NkJodemJyM7 Qy1Yv-zewCM5vasfisuTYq_ifNy_N42SoBOeHJ4-jH5OIP1QiVsAubZ3WTLKnPDQVIfMijRgc5wmwz22h55cu-gAmKKz9i-l4YXTRI_Vh2jq6Cl_niGRJrH55viD-NWcXNVqrzdj8qoUTMBuV9n5A-73HFEfRc5eiFg-e9hgo8BKb4tCekds1mi7_22V5Jk7X7obpovoojgbMcpZcIiSep cKvBq2vQ-8qIvPclT6MRIL6Q2zyq8Mh1VZ2e7JYiu_8GAvYfHIJdSKoO3Z4 ZECB4Xdv1uaNoezmewnszp2x2uBplfSN4zgbkHd5kv1y0NibE0 1Bk=w1080-h810-no[/IMG]
TB cover plate cleaned.
For some reason, took ages removing the melted potting from the CRK/CYL sensor because it was really sticky.
Also, due to loose TB tension, there was significant amount of rubber like dust accumulated so not fun cleaning it without the mask.
Later spec WP installed and carefully torqued to the spec in sequence.
Looking good.
