Eng Refresh + LMA, Brake OH, etc 33
, 03-02-2017 at 12:57 PM (3353 Views)
Before placing the Eng/Gbox assy back in place, cleaned the engine bay as much as possible.
Some of the before/after photos.
Centre floor coolant pipes replaced.
The crank shaped hose was really soft so it was good time replacing all of the coolant hoses.
I think I’ll replace the FR brake pipe before replacing the Rad.
Really tight space and although we are going to replace the master cyl any way, previous leakage caused big rust at the booster housing.
Also, the owner already told me that one of the brake line was replaced in the past.
Probably it was pressed against the body work without being noticed, scratched and started leaking after many years.
As always, very important to check whenever worked inside the front compartment as there are many Hyd lines inside there.
I think I'll have fun dealing with these rusty bolts on the rad fan shroud....
Hope to fireup the engine very soon.
