T3TEC ABS Upgrade Loom
, 15-11-2016 at 01:48 PM (3139 Views)
The ABS upgrade loom from T3TEC, Japan.
I know there is another place in Japan selling similar loom and I'm quite sure that is the one sold by many vendors outside of Japan.
However, I prefer T3TEC one because the other one is using soldering method at the white 20 and 18pin connectors resulting in
solder crack over long time if the installer didn't secure the wires against the vibration.
With my background, I never use soldering method at the connector if the vibration can cause issue.
Applied some modifications using extra parts, wires, etc to make it more user friendly.
The user will receive my English version of installation manual including the diagnosis procedure in case of future ABS warning light.
Soon to be installed with this.
