Fuel Filter
, 18-05-2011 at 11:15 PM (2062 Views)
Before putting everything back on the car during TB/WP/Valve service, decided to replace the Fuel Filter while there is extra space around the area.
Photo and PC Display won’t show the actual colour without calibration but the fuel came out from the old filter was light brown so not too bad.
New filter and washers waiting to be installed.
New Filter installed and will be double checked once fuel pressure is applied.
As always, make sure to double check that the fuel pipes are not touching any of the body work.
On almost all of the UK NSX, I noticed that at least one of the pipe was scratching against the actual fuel filter bracket.
This photo was taken from behind/side of the fuel filter so unless you look from the specific angle, you won’t be able to check this.
Good clearance and happy with it.
