Brake OH, Cooling Sys, etc 29
, 22-10-2016 at 12:41 PM (2078 Views)
Already tested on the bench but pre-installed the iPod adaptor USA Spec PA11-HON inside the cabin
using the breakout point behind the left side seat.
Tested the head unit using my ancient iPod Mini or whatever it was called years ago.
FM Frequency expander is also working fine.
During the self diag test on the yellow NSX, it triggered Air Mix and Mode motor control issues and
with the severe damages on the circuit board, there was no way I can tell whether these were caused by
just the CCU or there are additional issues outside of the CCU.
So, I used my NSX with my display module first to test the refurbished CCU board.
I’m glad to report that there was no more Air Mix or Mode issue and I can now control the temperature as well as getting the air through Heater (footwell) position.
The air mix motor moving the water valve during the Function and Operation check to control the air temperature.
