Brake OH, Cooling Sys, etc 26
, 19-10-2016 at 12:29 PM (2105 Views)
Same story for the rear caliper although it involves the parking brake mechanism so extra process required.
Just for the parking brake, these parts are required.
Another bench check.
All four caliper and carrier bracket set back on the car.
Once again, thank you to Bigg Red for their nice premier coating.
As mentioned many times, install the brake hose without twisting force.
NSXCB spec Goodridge brake hose. Very nice and custom made to have 2 line locators/fixings at the front and
length suitable for OEM earlier small and later large brake systems.
There was no way I can re-use the banjo bolt so all four replaced with new one.
