Emergency Gauge/Tail Light Assy service 05
, 06-09-2016 at 12:53 PM (2040 Views)
Carefully installed the unit with the help of masking tape around the edge.
Took the photo to show all the light bulbs including the turn signal.
I can only adjust tiny amount of alignment over several hours as the OEM gasket needs to settle and compressed first.
After leaving them overnight, will do the proper alignment today.
Although already confirmed using the used light bulbs, double checked the ‘BRAKE LAMP’ warning feature and parking brake indicator.
Of course, no more issues but will carry on with multiple testing under different temperature conditions.
Not easy to show the actual appearance using digital camera but these photos show how they look.
For human eyes, very bright and evenly matched lighting beam angle.
Will check the speedo against GPS and adjust it if required.
Already washed the car at the very beginning of the emergency service so should be ready very soon.
