AC Refresh 09
, 20-08-2016 at 11:48 AM (1937 Views)
Before installing the evapo, I’m going to apply 12V at each actuator in both direction to check the flap/damper movement.
I don’t want to get strange noise after installing the dashboard......
In the background, started assembling the tail light assy for another owner.
The complete assy is no longer available so you must install all the sensor, wires, bulbs, bezel, etc by yourself but
looks so much better and saves time than melting the old glue to open the existing unit with already warped plastic material.
