Cooling Sys, Health Check, etc 29
, 15-07-2016 at 11:39 AM (2622 Views)
Also, the fluid was still sitting at the mating surface of the brake booster cover.
Had to clean it and create smooth surface to get good vacuum seal before installing the new master cyl.
From the paint marking, I already knew that this master cyl was never touched but
I always check the push rod clearance in case someone decided to touch the adjuster behind the booster.
Bench bleeding the new master cyl.
Just need to pressure bleed the brake system while refurbishing the drive shaft,
leave it overnight and then another pressure bleeding next day.
Then, the a/c CCU board service, ABS, etc.
Getting there…..
