Cooling Sys, Health Check, etc 27
, 15-07-2016 at 11:32 AM (2461 Views)
Time for the installation.
Nice looking EBC Front disc.
Goodridge Custom made NSXCB spec brake line.
Carefully installed preventing any twist while applying torque at the fitting.
New banjo bolt and bleeder plug.
The owner will see the photos for both R&L sides but for here, I’ll just show the R side.
At the rear, in ideal world, this pad should be installed at the inner side but since it spent some time at the outer side,
I have no option but to install it in the same way as before.
Also, at the inner pad, the wear indicator was placed at the bottom side when it should have been at the upper side.
Again, I have no option but to install it in the wrong orientation.
